AutoSave supports non-networked devices by allowing you to make changes to programs in the field then analyze and sync all changes to the server back at the office.
Posted: 2019-03-14 04:19 AM . Last Modified: 2019-03-14 07:33 AM
We have multi vendor devices across the plant network globally. Also some of them are networked and some of the devices are non-networked. In such a scenario, can someone help us tackle change management easily without much impact on operations?
Posted: 2019-03-19 07:59 AM
MDT Automation Change Management software can be used to manage source code in both non-networked/connected devices and non-networked/disconnected devices. Interacting seamlessly with editor packages, AutoSave provides: version control, archival backups, change detection, change documentation, historical tracking, secured user access, disaster recovery and automatic change notification in anyPC-based application and more automation devices than any other change management software in the industry, including PLC, robots, CNC, welders, drives, HMI, workstations, project files and documents.
• View a history of changes performed on each device
• Undo changes in the field with a simple button push
• Compare the program running in the device to the program on the engineer’s laptop
• Copy programs to create new programs in the field
