Can not download to a xbtgt7340 HMI
  • Industrial Automation
  • Can not download to a xbtgt7340 HMI
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Schneider
HMI Screen Templates for EcoStruxure™ Operator Terminal Expert
HannesB
HannesB
Cadet
Posted: ‎2025-07-06 10:51 PM
426
When downloading to this HMI (using Vijeo designer  6.2), the HMI exits the running application and goes into transfer mode, showing progress at 0% but then no further progress is shown. On the PC side, the download eventually fails but the HMI stays on the transfer screen (0%).
It used to be on an older service pack version, using an older PC (with the above-mentioned results) and I managed to download once from my Windows 11 PC which upgraded the runtime version to SP12 on the HMI but thereafter the same problem occurred.
Any ideas?
  • Process Automation Talks
JerryBartlemay
Lieutenant JG
Posted: ‎2025-07-08 07:47 AM
395
Have you tried using a USB stick to transfer the program?  It works well, and is not dependent on comms integrity.
ismailozinan
Lt. Commander ismailozinan Lt. Commander
Lt. Commander
Posted: ‎2025-07-09 04:56 AM
if usb stick does not work, in this case there is recovery solution. It might be worked.But it is doing by after sales support of schneider with Runtime installer exe.
https://www.se.com/tr/tr/faqs/FA195930/
HannesB
HannesB
Cadet
Posted: ‎2025-07-10 09:27 PM
In response to JerryBartlemay
Thanks for the reply, Jerry. The HMI is on a remote site so it would be nice to find an Ethernet-based solution. Otherwise I'll look at the USB method.
