Bug: Control Expert Classic Freezing on adding CRA module
  • Industrial Automation
  • Bug: Control Expert Classic Freezing on adding CRA module
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Control Expert
Brendon1
Crewman Brendon1
Crewman
Posted: ‎2025-02-19 02:41 PM
2
1048
Control expert freezes at 30% when attempting to add a .x80 remote drop to the EIO bus.
This effects Control Expert Classic V15 and V16 and seems to be the result of the process requesting additional licenses when it already has one out.
It occurs when a license with only 1 usage right is added in the floating license manager
Vender Daemon Log
\schneide.log
10:02:49 (schneide) OUT: "CEX_StartUp" Automation@WINDOWS11_CLEAN
10:02:49 (schneide) OUT: "CEX_Extra_Large_XL" Automation@WINDOWS11_CLEAN
10:02:49 (schneide) OUT: "CEX_Safety" Automation@WINDOWS11_CLEAN
10:40:03 (schneide) Multiple dup-groupings in effect for CEX_StartUp:
10:40:03 (schneide) 	HOST  vs. NONE
10:40:03 (schneide) 	No further warnings about this.
10:40:03 (schneide) DENIED: "CEX_StartUp" Automation@WINDOWS11_CLEAN  (Licensed number of users already reached. (-4,342))
10:40:36 (schneide) DENIED: "CEX_StartUp" Automation@WINDOWS11_CLEAN  (Licensed number of users already reached. (-4,342))
10:41:09 (schneide) DENIED: "CEX_StartUp" Automation@WINDOWS11_CLEAN  (Licensed number of users already reached. (-4,342))
10:41:43 (schneide) DENIED: "CEX_StartUp" Automation@WINDOWS11_CLEAN  (Licensed number of users already reached. (-4,342))
10:42:16 (schneide) DENIED: "CEX_StartUp" Automation@WINDOWS11_CLEAN  (Licensed number of users already reached. (-4,342))
10:42:48 (schneide) DENIED: "CEX_StartUp" Automation@WINDOWS11_CLEAN  (Licensed number of users already reached. (-4,342))
10:43:20 (schneide) DENIED: "CEX_StartUp" Automation@WINDOWS11_CLEAN  (Licensed number of users already reached. (-4,342))
10:43:52 (schneide) DENIED: "CEX_StartUp" Automation@WINDOWS11_CLEAN  (Licensed number of users already reached. (-4,342))
10:44:25 (schneide) DENIED: "CEX_StartUp" Automation@WINDOWS11_CLEAN  (Licensed number of users already reached. (-4,342))
10:44:59 (schneide) DENIED: "CEX_StartUp" Automation@WINDOWS11_CLEAN  (Licensed number of users already reached. (-4,342))
If this is expected behavior then the process should timeout and give the user a descriptive error message.
  • Process Automation Talks
Ricard
Lt. Commander Ricard Lt. Commander
Lt. Commander
Posted: ‎2025-02-20 11:43 PM
1
1020
Hello @Brendon1 ,
Thank you very much for sharing your experience, this is precisely one of the community's goals, to share our experiences so that we can all resolve our doubts, and consequently improve our product.
It would be advisable for you to contact technical support in your country. I don't quite understand the circumstance that has led you to conclude that there is a problem, but I am convinced that if you contact technical support they will be able to help you.
I insist on thanking you for the post
Ricard
Ricard
Lt. Commander
1
1021
Hello @Brendon1 ,
Ricard
Brendon1
Crewman Brendon1
Crewman
Posted: ‎2025-02-23 01:52 PM
In response to Ricard
Hi Ricard,
Thanks for the advice. I have already fixed this problem by changing the number of usage rights used. I am posting here so if anyone else gets stuck with this issue they'll find a solution faster.
