ALTIVAR DRIVE TO SOMOVE SOFTWARE CONNECTION FOR LV434211 CABLE
  • Industrial Automation
  • ALTIVAR DRIVE TO SOMOVE SOFTWARE CONNECTION FOR LV434211 CABLE
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Altivar Process (Low Voltage)
Rishi1
Crewman Rishi1
Crewman
Posted: ‎2023-03-16 12:15 AM
2008
HOW TO CONNECT lv434211 CABLE WITH SOMOVE SOFTWARE AND ALTIVAR DRIVE,I NEED TO KNOW THE SETUP FOR HARDWARE CONNECTION.THERE ARE TX+,TX,SHLD,GND,RX+ &RX- IN THE COMMUNICATION CABLE.I HAVE RS 485 TO USB CONNECTOR ALSO WITH ME.
  • Smart Operations
KJBER
Ensign KJBER
Ensign
Posted: ‎2023-03-16 12:32 AM
I normally use TCSMCNAM3M002P cable for this, but there is a pinout in the instruction sheet from attached link that you can try.
https://www.se.com/ww/en/product/TCSMCNAM3M002P/connection-cable-usb-rj45-for-connection-between-pc-...
Pinout:
Also, you can use the rotary setting button on the drive to set IP adress and then connect to the drive via SoMove ethernet, if you cant get the USB interface to wok.
Good luck
