Using the GroupManagement/GroupControl objects to configure group/subgroup route & sequences – EPE 2021
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • Using the GroupManagement/GroupControl objects to configure group/subgroup route & sequences – EPE 2021
  • hTapiaF
    hTapiaF
  • Vartika
    Vartika
Modicon M580
EcoStruxure™ Process Expert
EcoStruxure™ Process Expert - Mining Library
Back to Industrial Automation Knowledge Base
Ensign hTapiaF Ensign
‎2022-06-28 07:02 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
This document will help you understand and use the $GroupMGTGP/$GroupCTLGP objects to quickly
configure start/stop sequences of assets, routes and also generate subgroups that are part of the main
sequence. These objects are part of the “Group Control Library”.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
