Lexium Cobot - Inverse Kinematics (How to Define Arm Configuration)
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • Lexium Cobot - Inverse Kinematics (How to Define Arm Configuration)
  • Stefan_Winkler
    Stefan_Winkler
Back to Industrial Automation Knowledge Base
Lieutenant JG Stefan_Winkler Lieutenant JG
‎2024-03-14 09:39 AM
Last Updated: Commander TristanPowell Commander ‎2024-03-14 10:00 AM
Kinematic calculations help to transform joint into cartesian values and vice versa.
But how to define the robot arm configuration (e.g. elbow up or elbow down) while sending the robot to a defined position in cartesian space?
Using inverse kinematics the mendatory entry of a reference positions solves this issue.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • Robotics
InverseKinematics.zip
Rate this article:
(1)
100% helpful (2/2)
