KB - System Time Stamping Solution without Programming
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • KB - System Time Stamping Solution without Programming
  • Michael_Chan
    Michael_Chan
  • Vartika
    Vartika
Modicon M580
EcoStruxure™ Control Expert
OPC Factory Server
field url
AVEVA
AVEVA™ Plant SCADA
Load more
Back to Industrial Automation Knowledge Base
Commander Michael_Chan Commander
‎2022-11-02 12:45 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
There are two available solutions to implement time stamping with EcoStruxure Control Expert, both methods are easy to implement and can be selected for use in almost any circumstance.
  1. Applicative – A function block is required for third-party SCADA to convert and read the information
  2. System – No programming is required (some components are needed)
System and Applicative time stamping modes are exclusive in the same EcoStruxure Control Expert application running in the controllers. In this article, we will investigate the System Time Stamping solution.
System Time Stamping provides a consistent SOE (sequence of events), time stamped at the source, to allow the user to analyse the source of abnormal behaviour in a distributed automation system. The SOE is displayed in an alarm summary or SOE page of a client (such as a SCADA). Each source of time stamped event of the SOE is a discrete I/O value change (transition) detected by a time stamping module, this event is then passed through to OFS and straight to the SCADA.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (2)
  • M580
  • timestamp
Rate this article:
(1)
100% helpful (1/1)
