KB - How to Manage Online Modification to a Modicon M580 Standby CPU
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • KB - How to Manage Online Modification to a Modicon M580 Standby CPU
  • Michael_Chan
    Michael_Chan
  • Vartika
    Vartika
EcoStruxure™ Control Expert
Back to Industrial Automation Knowledge Base
Commander Michael_Chan Commander
‎2023-05-09 09:05 PM
Last Updated: Lieutenant Vartika ‎2023-11-29 04:08 AM
There are some scenarios where making online modifications on the standby CPU of a hot standby system may be necessary. For example, if there are changes to the process or system configuration that need to be implemented immediately, and the primary CPU is not available, making online modifications on the standby CPU may be necessary to ensure continuity of the process.
To make online modifications to an application program, a logic mismatch signal will be enabled to allow a Hot Standby system to continue operating even if there is a mismatch between the applications in the Primary and Standby CPUs. The Logic Mismatch feature will be used to modify an application program and the I/O configuration while the process remains redundant.
This document describes the procedure to perform an online modification to a Modicon M580 Standby controller.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • node-red
Rate this article:
