KB - How to Connect Non-Compliant Profinet S2 Intelligent Electronic Device (IED) with Profinet S2 System
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • KB - How to Connect Non-Compliant Profinet S2 Intelligent Electronic Device (IED) with Profinet S2 System
  • MuhammadPadli
    MuhammadPadli
  • Vartika
    Vartika
Back to Industrial Automation Knowledge Base
MuhammadPadli Schneider Alumni (Retired)
‎2020-12-31 08:44 AM
Last Updated: Lieutenant Vartika ‎2023-11-29 02:37 AM
Intelligent Electronic Device (IED) is a microprocessor-based device of power system equipment that can receive and sent data from and to controller of a process control system. Schneider Electric have several IED such as: Tesys T and Altistart for motor starter purpose, and Altivar process drive.
Profinet is an industry technical standard for data communication between controllers and devices over Industrial Ethernet. Profinet is developed from Profibus by Profibus & Profinet International (PI). Profinet have its own redundancy system that is defined into four types: S1, S2, R1 and R2.
This document is aimed to provide a report about possible methods can be deployed in order to make IED without built-in Profinet S2 capability to comply with Profinet-S2 redundancy system.
Please find resolution in the attached PDF file.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (2)
  • Altistart
  • ALTIVAR
Rate this article:
(1)
100% helpful (1/1)
