KB - EtherNet/IP Implicit Messaging implementation using EcoStruxure Process Expert
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • KB - EtherNet/IP Implicit Messaging implementation using EcoStruxure Process Expert
  • GunawanAdi
    GunawanAdi
  • TristanPowell
    TristanPowell
  • Vartika
    Vartika
EcoStruxure™ Hybrid DCS
EcoStruxure™ Process Expert
Back to Industrial Automation Knowledge Base
Ensign GunawanAdi Ensign
‎2020-08-07 10:00 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 04:05 AM
Introduction
According standard EtherNet/IP protocol, there are 2 types of messaging
  1. EtherNet/IP implicit messaging
  2. EtherNet/IP Explicit messaging
This exercise will assist to know EtherNet/IP concept and how to implement EtherNet/IP implicit messaging within EcoStruxure Process Expert solution approach.
Note: this procedure is validated and tested with EcoStruxure Hybrid DCS 2018
The concept of implementation is the same for later version of EcoStruxure Process Expert (EPE) (new name for EcoStruxure Hybrid DCS).
Please see attached document for detailed implementation.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (2)
  • dPAC
  • EcoStruxure Process Expert
Rate this article:
(1)
100% helpful (1/1)
