KB - Configuration of OI.MBTCP driver in AVEVA System Platform and publish data in AVEVA Insight
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • KB - Configuration of OI.MBTCP driver in AVEVA System Platform and publish data in AVEVA Insight
  • FranHerrera
    FranHerrera
  • Vartika
    Vartika
AVEVA Group PLC
AVEVA™ Insight
AVEVA Group PLC
Back to Industrial Automation Knowledge Base
Lieutenant FranHerrera Lieutenant
‎2021-07-12 09:23 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
This document will help you in the integration and configuration of the IO.MBTCP driver for AVEVA System Platform as well as in the integration of the AVEVA Insight cloud historization solution.
For this proof of concept, we have created a small application in M580 with a localized variable. This variable will be read through IO.MBTCP Driver and then will be published in AVEVA Insight.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (2)
  • AVEVA
  • AVEVA System Platform
Rate this article:
