How to reduce broadcast domain in EcoStruxure Plant Architecture
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • How to reduce broadcast domain in EcoStruxure Plant Architecture
  • anujgupta
    anujgupta
  • Vartika
    Vartika
Back to Industrial Automation Knowledge Base
Ensign anujgupta Ensign
‎2020-10-06 09:10 PM
Last Updated: Lieutenant Vartika ‎2023-11-29 03:17 AM
While configuring Ethernet architecture it is very common mistake, where engineers create loops and end up with unreliable network due to broadcast storms.
For complex architectures it is very important to implement segmentation or VLAN or both. One of such example is defined in the document attached.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • M580
Rate this article:
(1)
100% helpful (1/1)
