How to Use EcoStruxure Machine Expert Twin SmartVisu to Emulate Robot Applications
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • How to Use EcoStruxure Machine Expert Twin SmartVisu to Emulate Robot Applications
  • SvenBrand
    SvenBrand
Back to Industrial Automation Knowledge Base
Lieutenant SvenBrand Lieutenant
‎2025-02-11 06:03 AM
on ‎2025-02-11 06:03 AM
Objective
The purpose of this article is to highlight the steps needed to set up a SmartVisu in EcoStruxure Machine Expert Twin for a robot application. This article is not dealing with target handling, it shows how to add static objects (Robots, Conveyors).
This article highlighted how to set up a SmartVisu in EcoStruxure Machine Expert Twin. It explained the steps required to create static objects for a robot application and guided the reader through the necessary procedures in the related software.
AttachedFiles.zip
Rate this article:
