How to Regain Access to EcoStruxure Process Expert System Server
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • How to Regain Access to EcoStruxure Process Expert System Server
  • MuhammadPadli
    MuhammadPadli
  • TristanPowell
    TristanPowell
  • Vartika
    Vartika
EcoStruxure™ Hybrid DCS
Back to Industrial Automation Knowledge Base
MuhammadPadli Schneider Alumni (Retired)
‎2020-08-04 11:30 PM
Last Updated: Lieutenant Vartika ‎2023-11-23 02:51 AM
Are you experiencing problem logon into EcoStruxure Process Expert System Server?
Are you forgot the password?
Or you want to set up another user name?
If your server or workstation is managed and connected to domain controller then simply ask your domain administrator to re-set your password or give your account access to the roles of “ESX HDCS System Admin”.
However, if the server or workstation is managed by your-self running on Physical Machine or Virtual Machine (VM) then this document will guide you how to regain your access to EcoStruxure Process Expert System Server in above case.
There are some workarounds to resolve this problem. This document will explain all possible workarounds and considerations you need to take before determining the method suits your case.
All methods described in this document need access privilege to manage user accounts. This activity will be performed from “Computer Management” feature of Windows.
Find the details in the attachment file of this article.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • EPE
Tags (2)
  • EcoStruxure Hybrid DCS
  • EcoStruxure Process Expert
Rate this article:
