How to Read and Change a String from the HMI in EcoStruxure Automation Expert
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • How to Read and Change a String from the HMI in EcoStruxure Automation Expert
  • TalitaQueiroz
    TalitaQueiroz
  • TristanPowell
    TristanPowell
  • Vartika
    Vartika
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lieutenant TalitaQueiroz Lieutenant
‎2022-09-30 06:42 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
​When reading a string from the logic and displaying it in EcoStruxure Automation Expert, sometimes the user needs to change it from the HMI, it is not natively possible using drag & drop whilst creating a CAT.
This knowledge base will show how to customize and do the C# code to not only read the string from the input, but to allow you to change the string from the HMI and update the output.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
