How to Determine the Optimal CPU Performance for Modicon M580 Safety
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • How to Determine the Optimal CPU Performance for Modicon M580 Safety
  • Michael_Chan
    Michael_Chan
  • Vartika
    Vartika
Modicon M580
Back to Industrial Automation Knowledge Base
Commander Michael_Chan Commander
‎2022-10-01 09:29 PM
Last Updated: Lieutenant Vartika ‎2023-11-29 03:48 AM
The Modicon M580 Safety controller can execute single task and multi-task applications. Unlike a single task application which only executes the MAST task, a multi-task application defines the priority of each task. When a task is running, it can be interrupted by another task with a higher relative priority.
For example, when a periodic task is scheduled to execute its code, it would interrupt a lower priority task, but would wait until the completion of a higher priority task.
For optimal CPU performance, Schneider Electric recommends that the total percentage of CPU bandwidth consumed by an application not exceed 80%.
Users will need to determine the CPU bandwidth and fine tune to adjust the tasks period for an optimal CPU performance.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • Cybersecurity
Rate this article:
(1)
100% helpful (1/1)
