How can EcoStruxure OPC UA Server Expert use Topological Addressing
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • How can EcoStruxure OPC UA Server Expert use Topological Addressing
  • Michael_Chan
    Michael_Chan
EcoStruxure™ Control Expert
EcoStruxure™ OPC UA Server Expert
Back to Industrial Automation Knowledge Base
Commander Michael_Chan Commander
‎2023-12-07 01:37 AM
on ‎2023-12-07 01:37 AM
How can I obtain data values from any Modbus devices utilizing the State RAM topological objects (%MW, %M, %S, %SW, %KW, %I, and %IW) via EcoStruxure OPC UA Server Expert without having to install the EcoStruxure Control Expert programming software?
Using the EcoStruxure OPC UA Server Expert Configuration Tool, enable the Populate option, we can use topological addressing to retrieve data values from the EcoStruxure OPC UA Server Expert without the requirement to create located and unlocated variables in EcoSruxure Control Expert.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • OPC UA
Rate this article:
100% helpful (1/1)
