How Can I Manage a QuickConnect Device
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • How Can I Manage a QuickConnect Device
  • PhilippeCosta
    PhilippeCosta
  • Vartika
    Vartika
Back to Industrial Automation Knowledge Base
Ensign PhilippeCosta Ensign
‎2020-02-27 04:58 AM
Last Updated: Lieutenant Vartika ‎2023-11-29 03:42 AM
Schneider Electric provides common Ethernet/IP communication feature on M340 and M580.
In typical robotic application where a robot arms quickly exchanges tools to switch tasks, it takes about 10 seconds for the communication to be connected in common Ethernet/IP.
The robot can disconnect and reconnect on the fly a new tool without stopping the manufacturing process.
EtherNet/IP QuickConnect technology enables EtherNet/IP devices to quickly power up and connect an EtherNet/IP network and start I/O cyclic data exchange in less than 500ms.
Performance Requirements
The time to establish a connection depends on the end device :
- An EtherNet/IP QuickConnect device powers up in ≤ 300 ms (power on)
- An EtherNet/IP controller and network infrastructure establishes connection in ≤ 200 ms (scanner on)
Even if by the current design of the NOC modules (M340 and M580) QuickConnect feature is not implemented, this article will explain how to setup and manage QuickConnect devices.
See the attachment below.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (2)
  • drives
  • M580
Rate this article:
