General Purpose Library and Monitoring Module Health
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • General Purpose Library and Monitoring Module Health
  • RobertSanders
    RobertSanders
EcoStruxure™ Control Expert
General Purpose Library V2 for EcoStruxure™ Control Expert
Back to Industrial Automation Knowledge Base
Lt. Commander RobertSanders Lt. Commander
‎2024-12-24 07:10 AM
on ‎2024-12-24 07:10 AM
Within the General Purpose Library there are a set of function blocks called Signal Processing, which can be used to monitor the X80 module status.
The following Knowledge Base article uses the Signal Processing function blocks from the Modicon General Purpose Library to monitor Channel health and Module health.
Download the attached PDF for instructions.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
