Ecostruxure Automation Expert - Edge I/O integration with EtherNet/IP
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • Ecostruxure Automation Expert - Edge I/O integration with EtherNet/IP
  • Eric_Coudurier
    Eric_Coudurier
  • TristanPowell
    TristanPowell
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander Eric_Coudurier Lt. Commander
‎2025-06-04 02:40 AM
Last Updated: Commander TristanPowell Commander ‎2025-06-09 06:42 AM
Ecostruxure Automation Expert integrates a new tool to configure the Edge IO islands.
The purpose of this document is to show how to use the Edge IO configurator tool integrated into EAE, to create an EtherNet/IP connection between an Edge IO island and a Soft dPAC PLC running in a Linux virtual machine.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (4)
  • dPAC
  • Fieldbus
  • Function Block Programming
  • IEC 61499
Rate this article:
(1)
100% helpful (1/1)
This is a heading
