EcoStruxure Process Expert - Topology Synchronization
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Process Expert - Topology Synchronization
  • Richard
    Richard
Back to Industrial Automation Knowledge Base
Lt. Commander Richard Lt. Commander
‎2024-08-23 09:08 AM
on ‎2024-08-23 09:08 AM
When using the Topology Explorer in EcoStruxure Process Expert 2023, most changes are immediately saved to the database. However, sometimes they are not, leaving the topology out of synchronization with the controller configuration, which can lead to issues with the control project.
This document explains the signs to look out for if the topology has not been synchronized correctly, and how to perform a synchronization.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
(1)
100% helpful (1/1)
