EcoStruxure Process Expert: Client and Scanner Modbus serial communication
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Process Expert: Client and Scanner Modbus serial communication
  • Eric_Coudurier
    Eric_Coudurier
  • Vartika
    Vartika
Modicon M580
EcoStruxure™ Control Expert
EcoStruxure™ Process Expert
field url
EcoStruxure™ Process Expert for AVEVA System Platform
Load more
Back to Industrial Automation Knowledge Base
Lt. Commander Eric_Coudurier Lt. Commander
‎2020-12-11 04:40 AM
Last Updated: Lieutenant Vartika ‎2023-11-22 02:24 AM
Using Modbus serial communication with third-party equipment requires complex logic to manage priorities and diagnostics.
The General Purpose library (GPL) has powerful functions and only needs a simple configuration for the implementation of this communication.
This document shows the implementation of a serial Modbus client and scanner communication, in EcoStruxure Process Expert.
The GPL library is also available for EcoStruxure Control expert as a standalone library and the two examples described can be easily reused on this software platform.
Library link: https://shop.exchange.se.com/en-US/apps/66288/general-purpose-library-v2-for-ecostruxure-control-exp...
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (4)
  • Control Expert
  • EPE
  • M580
  • PROCESS EXPERT
Rate this article:
(1)
100% helpful (1/1)
