EcoStruxure Process Expert – BMENOC0321 Usage
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Process Expert – BMENOC0321 Usage
  • FranHerrera
    FranHerrera
  • Vartika
    Vartika
Back to Industrial Automation Knowledge Base
Lieutenant FranHerrera Lieutenant
‎2020-10-13 09:17 AM
Last Updated: Lieutenant Vartika ‎2023-11-29 04:08 AM
In some network architectures, the transparency of the network is necessary to be able to do configuration and commissioning from a local engineering station without having to go to the field, reducing the time of downtime and commissioning.
This document explains the configuration of the BMENOC0321 Network Card to obtain transparency in the network without the need for the use of L3 switches.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (2)
  • node-red
Rate this article:
(1)
100% helpful (1/1)
