EcoStruxure Operator Terminal Expert v3.2 - Communication Scan Rate
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Operator Terminal Expert v3.2 - Communication Scan Rate
  • TomDroll
    TomDroll
  • TristanPowell
    TristanPowell
  • Vartika
    Vartika
EcoStruxure™ Operator Terminal Expert 3.1
Back to Industrial Automation Knowledge Base
Lt. Commander TomDroll Lt. Commander
‎2021-08-05 11:58 AM
Last Updated: Lieutenant Vartika ‎2023-11-23 12:46 AM
I want to be able to add multiple communication drivers to my HMI project, and configure the drivers to pull from the devices at different scan rates.
EcoStruxure Operator Terminal Expert v3.2 allows the project designer to add multiple scan rate configurations. The attached pdf will step through adding a scan rate to your project and applying to a project variable.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • Docker
Rate this article:
(3)
100% helpful (3/3)
