EcoStruxure Machine SCADA Expert Using VB Script to Create a Database in MS SQL
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Machine SCADA Expert Using VB Script to Create a Database in MS SQL
  • TomDroll
    TomDroll
EcoStruxure™ Machine SCADA Expert
Back to Industrial Automation Knowledge Base
Lt. Commander TomDroll Lt. Commander
‎2024-07-03 11:37 AM
on ‎2024-07-03 11:37 AM
Original Equipment Manufactures and Systems Integrators will transfer their EcoStruxure Machine SCADA Expert project to the Runtime once the project is completed.  In most cases, this requires a reconfiguration of the database connection, as well as manually adding the database to the SQL Server.
Using the Built-in functions, the database connection string can be saved in a project tag, and a VB Script can be used to create a database on the server from Runtime.  This article explains how.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • SQL
CreateDatabaseScript.zip
Rate this article:
