EcoStruxure Machine SCADA Expert - Using Screen Mnemonics
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Machine SCADA Expert - Using Screen Mnemonics
  • TomDroll
    TomDroll
  • TristanPowell
    TristanPowell
  • Vartika
    Vartika
EcoStruxure™ Machine SCADA Expert
Back to Industrial Automation Knowledge Base
Lt. Commander TomDroll Lt. Commander
‎2023-01-10 09:28 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:56 AM
The purpose of this Knowledge Base Article is to demonstrate the passing of Custom Properties or Screen Mnemonics when opening a screen that was created using the native screen editor. It shows how to use the Open() screen command to open a native screen setting the screen attributes and  passing variable data to the opening screen.
Use the screen Open() command with advanced syntax to pass variable values into the opening screen.
Open(strScreenAndProperties,optNumX1,optNumY1,optNumX2,optNumY2,optNumResizeFlag,optNumID,optStrMnemonicList)
See the attached assets for further information.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (3)
  • Cloud Connectivity
  • SCADA
KBA ScreenMnemonics.zip
Rate this article:
(1)
100% helpful (3/3)
