EcoStruxure Machine SCADA Expert - Unit Conversion
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Machine SCADA Expert - Unit Conversion
  • TomDroll
    TomDroll
EcoStruxure™ Machine SCADA Expert
Back to Industrial Automation Knowledge Base
Lt. Commander TomDroll Lt. Commander
‎2025-01-22 08:08 AM
Last Updated: Commander TristanPowell Commander ‎2025-01-22 08:08 AM
How can I create a project that can display different units from the same source value. For example, switching between degrees Celsius to degrees Fahrenheit.
EcoStruxure Machine SCADA Expert tags have a property for data Unit. Using this property with the Built-in script function SetDisplayUnit, gives the operator the ability to chose which units to display.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
(1)
