EcoStruxure Machine Expert - How to Secure Email between M241 Controller and Public Email Server using Stunnel
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Machine Expert - How to Secure Email between M241 Controller and Public Email Server using Stunnel
  • Lrhaouch
    Lrhaouch
  • Vartika
    Vartika
Back to Industrial Automation Knowledge Base
Lieutenant JG Lrhaouch Lieutenant JG
‎2023-06-06 01:09 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
The EmailHandling library implements function blocks to send and receive emails with the controller application support secure and unsecure communication with an email server.
Since it is not recommended to use unsecure communication over public networks and above all over the internet.
Furthermore, the most popular public email servers do not support unsecure communication. Therefore, a direct communication between the M241/M251 controller and the public email server is not possible.
To address this issue, the recommended third-party tool to use is stunnel.
Stunnel is a proxy designed to add TLS encryption functionality to existing clients (controllers) and servers (public email) without any changes in the program’s code.
Stunnel uses the OpenSSL library for cryptography, so it supports whatever cryptographic algorithms are compiled into the library.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
