EcoStruxure Machine Expert - How to Encrypt the Communication between M262 Client and MQTT Broker
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Machine Expert - How to Encrypt the Communication between M262 Client and MQTT Broker
  • Lrhaouch
    Lrhaouch
  • Vartika
    Vartika
Back to Industrial Automation Knowledge Base
Lieutenant JG Lrhaouch Lieutenant JG
‎2023-05-26 04:04 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
To encrypt data exchanged between M262 Client and MQTT broker, a certificate is required. Without a valid certificate the communication between the two communicating parties is not secured.
To create a valid certificate OpenSSL is used. OpenSSL is a widely-used open-source software library that provides cryptographic functions and protocols. It is designed to provide a toolkit for secure communication over computer networks and to implement encryption, decryption, digital signatures, and other cryptographic operations.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
