EcoStruxure Machine Expert - Changing Homing Modes of LXM32S by Software
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Machine Expert - Changing Homing Modes of LXM32S by Software
  • Wolfram64
    Wolfram64
  • Vartika
    Vartika
EcoStruxure™ Machine Expert with M262: Module 5: Motion - VIRTUAL
Back to Industrial Automation Knowledge Base
Lieutenant JG Wolfram64 Lieutenant JG
‎2022-10-26 03:26 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
The Homing Method of Lexium32S is normally fixed in advance by the Software 'SoMove'. Sometimes it makes sense to handle the Homing Method individually, according to the actual situation. Changing Homing Method e.g. change of Homing direction via extra connection and SoMove is not acceptable.
This KB article shows, how to change Homing Methods within program (based on EcoStruxure Machine Expert). This KB shall give you also ideas, how to find out, how to influence other Parameters of the Lexium Drive, e.g. Handling the brake state of a connected Motor.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (2)
  • Lexium
  • programming
Rate this article:
(1)
100% helpful (1/1)
