EcoStruxure Machine Expert – Certificate Handling for Microsoft SQL Server Running in a VM
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Machine Expert – Certificate Handling for Microsoft SQL Server Running in a VM
  • TristanPowell
    TristanPowell
  • Lrhaouch
    Lrhaouch
  • Vartika
    Vartika
EcoStruxure™ Machine Expert
Back to Industrial Automation Knowledge Base
Lieutenant JG Lrhaouch Lieutenant JG
‎2022-10-10 11:20 PM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
The main issue you will face when you trying to manage the secure connection (via SSL encryption) between the SQL Gateway and the Microsoft SQL server running in a VMware Machine is that the generated certificate (also self-signed certificate) will not appear at the Server side.
Please see attached document.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
(1)
