EcoStruxure Control Expert and Modicon Edge I/O NTS using Explicit Communications
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Control Expert and Modicon Edge I/O NTS using Explicit Communications
  • DavidBillingham
    DavidBillingham
Back to Industrial Automation Knowledge Base
Ensign DavidBillingham Ensign
‎2025-08-11 08:41 AM
on ‎2025-08-11 08:41 AM
There are many ways of natively communicating between an EcoStruxure Control Expert based control system and a Modicon Edge I/O NTS Island, most involve stopping the CPU to download a new configuration.
This document presents another method, explicit communications using the DATA_EXCHANGE function block.
This function block can be used to code Modbus requests other than those provided in the READ_VAR and WRITE_VAR functions. Specifically, the simultaneous read/write Modbus function.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
