EcoStruxure Automation Expert - enabling the Asset Label (Instance Name) within AVEVA Industrial Graphics
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert - enabling the Asset Label (Instance Name) within AVEVA Industrial Graphics
  • RobertSanders
    RobertSanders
AVEVA Group PLC
AVEVA System Platform
Back to Industrial Automation Knowledge Base
Lt. Commander RobertSanders Lt. Commander
‎2023-12-23 05:46 AM
on ‎2023-12-23 05:46 AM
Many AVEVA Industrial Graphic symbols supplied within the AVEVA.IndustrialGraphics library can display the Asset Label (Instance Name), however by default it is not configured.
In the following example the Label on the valve symbol should be V003.
The following Knowledge Base article details the steps required to display the Asset Label (Instance Name) on a symbol.
Step 1 – Enable the Label display
  1. Open the symbol within the CAT and select it.
  2. In Properties select the LabelType and set to ObjectTagname
Step 2 – Add the ability to enable / display the visibility for the Label
  1. Click on the Object, right-click and select Custom Properties.
  1. Select the LabelVisible Default value to MyViewApp.Settings.LabelVisible
  1. Save and close the Symbol.
  2. Create / Update the new template in AVEVA System Platform by using Sync AutoMapped .
  1. Once the Template has been created in AVEVA System Platform, use the CAT in your applications and synchronize to System Platform via the normal method, using the Deploy and Diagnostic Tab.
  1. Deploy and test - the Label can be turned on and off by selecting the banner symbol at the top
Use the Label slide switch to turn Visibility on or off.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
