EcoStruxure Automation Expert - Using the HMI Log File to Debug or Track Changes
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert - Using the HMI Log File to Debug or Track Changes
  • Eric_Coudurier
    Eric_Coudurier
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander Eric_Coudurier Lt. Commander
‎2025-01-28 05:19 AM
Last Updated: Commander TristanPowell Commander ‎2025-01-30 08:05 AM
For traceability reasons, it is sometimes necessary to time-stamp modifications made by the operator on the HMI and the controller's actions. The archiving function is one possibility. Another lighter option is to use the HMI log file. This function can be accessed directly from the HMI, using a few C# functions to record events. It can also be used to debug C# code to display messages or values, without having to use the debugging tool (Visual Studio) or the message boxes that require acknowledgement.
The aim of this document is to provide the information required to use the HMI log file.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • IEC 61499
HMItestLog.sln.zip
Rate this article:
(1)
100% helpful (2/2)
