EcoStruxure Automation Expert - Using NETIO to Send & Receive Data over WAN
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert - Using NETIO to Send & Receive Data over WAN
  • kingslim
    kingslim
  • TristanPowell
    TristanPowell
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander kingslim Lt. Commander
‎2024-06-26 12:44 AM
Last Updated: Commander TristanPowell Commander ‎2024-06-26 11:44 PM
Objective
This article provides 2 sample Solutions to show how NETIO can be used to send data from one machine to another. As the base protocol used is TCP/IP, data can be sent over large distances between 2 EAE Devices. The sample Function Block Network of the Solutions is explained, and you can run them in 2 different machines to test them out. The provided samples also serve as a base for you to build something bigger on top of them.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
NetIOB_20240625-125003825.sln.zip
NetIOA_20240625-124919677.sln.zip
Rate this article:
