EcoStruxure Automation Expert - Transitions, Parallel and Alternate Sequences
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert - Transitions, Parallel and Alternate Sequences
  • Richard
    Richard
  • TristanPowell
    TristanPowell
  • Vartika
    Vartika
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander Richard Lt. Commander
‎2023-07-21 09:05 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
I want to use Transitions and Branches in an EcoStruxure Automation Expert sequence.
This knowledgebase article describes how to use the sequence library transition and branching function blocks to create a managed sequence. It describes how they work and interact to create sequences that can be controlled by jumping to specific steps, rather than simply stepping through using the inbuilt monitoring timers.
Although EcoStruxure Automation Expert V23.0 will bring the new Procedural Library, this will only be a front-end to enable users to more easily create sequences that will be built using these sequence library function blocks. Understanding how they work will still be important for troubleshooting.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Rate this article:
(2)
100% helpful (2/2)
