EcoStruxure Automation Expert - Tips and tricks for using EAE: Update1
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert - Tips and tricks for using EAE: Update1
  • Eric_Coudurier
    Eric_Coudurier
  • TristanPowell
    TristanPowell
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander Eric_Coudurier Lt. Commander
‎2024-06-13 03:16 AM
Most people are unaware of certain elements that would help them browse and program more easily within EcoStruxure Automation Expert.
The aim of the document is to give some tips and tricks on how to use EcoStruxure Automation Expert more efficiently.
Tips and Trics:
  • Function Block Colors
  • Collapse Offline Parameters List
  • Quickly Switch from Application to Resource
  • Browse in the Function Blocks Network Editor
  • Tab Browsing
  • Cross Reference Links
  • Create Several Links Between FB’s
  • Hide Unused Ports
Update 1:
  • Improving the readability of constants in buildtime. (version > V24.0)
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (2)
  • Function Block Programming
  • IEC 61499
Rate this article:
(1)
100% helpful (4/4)
