EcoStruxure Automation Expert - Sequence Actions controlled by IDevice Adapters
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert - Sequence Actions controlled by IDevice Adapters
  • Eric_Coudurier
    Eric_Coudurier
  • ContentModerator
    ContentModerator
  • TristanPowell
    TristanPowell
EcoStruxure™ Automation Expert
SE.AppSequence library for EcoStruxure™ Automation Expert
SE.AppCommonProcess library for EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander Eric_Coudurier Lt. Commander
‎2024-10-28 03:13 AM
Last Updated: Crewman ContentModerator ‎2024-12-11 10:58 PM
The Sequence Library manages sequence actions based on symbolic links.
But there are several drawbacks using Step Actions:
  • Destination names entered manually in the Actions sequence, leading to potential errors that are difficult to detect.
  • Not easy to navigate between objects.
  • Difficult to maintain, as renaming an object requires restating names in actions.
  • Not easily portable, as object names are fixed in actions.
The aim of this document is to show how to control actions using another method based on the IDevice adapter.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (2)
  • Function Block Programming
  • General Purpose Library
IDeviceSequence_Completed.sln.zip
IDeviceSequenceStarter.sln.zip
IDeviceEncapsulated_20241202-173245974.sln.zip
Rate this article:
