EcoStruxure Automation Expert: Making an Aeration Process with WWW Library
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert: Making an Aeration Process with WWW Library
  • kingslim
    kingslim
  • TristanPowell
    TristanPowell
  • Vartika
    Vartika
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander kingslim Lt. Commander
‎2023-11-17 07:26 AM
Last Updated: Lieutenant Vartika ‎2023-11-22 02:55 AM
How do I utilise the new WWW Library released with EcoStruxure Automation Expert?
Objective
There is a new WWW Library released with the standard EAE installer. This library is rather user-friendly and allows us to engineer some specific processes in the water industry. The objective of this article is to, in the shortest time possible, teach you how to engineer an Aeration Process using objects from the Library. You will then run the Solution to see how it works.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • WWW
KB - 20231115 - WWW Library Aeration.zip
Rate this article:
