EcoStruxure Automation Expert: How to use JSON
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert: How to use JSON
  • Eric_Coudurier
    Eric_Coudurier
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander Eric_Coudurier Lt. Commander
‎2024-12-09 08:23 AM
on ‎2024-12-09 08:23 AM
MQTT, used for IIOT object communication, mainly uses JSON to encode information. This document will show you how EcoStruxure Automation Expert can handle JSON strings.
Understand JavaScript Object Notation and use the function blocs available in  EcoStruxure Automation Expert to create and parse JSON strings.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Labels (3)
  • Communication
  • Function Block Programming
  • IIoT
Using JSON.sln.zip
Rate this article:
