EcoStruxure Automation Expert - How to communicate with TM3 Bus Couple via Ethernet IP
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert - How to communicate with TM3 Bus Couple via Ethernet IP
  • Sweetly
    Sweetly
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Ensign Sweetly Ensign
‎2025-09-05 05:08 AM
Objective
The purpose of this article is to demonstrate the steps to setting the communication between EcoStruxure Automation Expert and TM3 Bus Coupler via EthernetIP protocol.
The attached document provides a step-by-step guide to setting the communication between EcoStruxure Automation Expert and TM3 Bus Coupler via EthernetIP protocol.
Rate this article:
