EcoStruxure Automation Expert: HMI Push Button using C# Events
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert: HMI Push Button using C# Events
  • Eric_Coudurier
    Eric_Coudurier
  • Vartika
    Vartika
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander Eric_Coudurier Lt. Commander
‎2022-09-26 03:46 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
Have you ever wondered how you get use C# Events within the HMI of EcoStruxure Automation Expert?
This document presents how to create an unlatched push button using events in C# in the HMI of EcoStruxure Automation Expert. The method can be applied to any other variable. It allows to trigger update events directly within the C# code.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • Automation Expert
PushButton_20220926-1242.sln.zip
Rate this article:
(2)
100% helpful (2/2)
