EcoStruxure Automation Expert: Display CAT Instance Name in the Faceplate Title.
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert: Display CAT Instance Name in the Faceplate Title.
  • Eric_Coudurier
    Eric_Coudurier
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander Eric_Coudurier Lt. Commander
‎2025-07-28 07:02 AM
In EcoStruxure Automation Expert HMI, It is possible to create a faceplate with a fixed title. However, by default, it is not possible to display the name of the CAT instance. The issue occurs when multiple faceplates are open simultaneously, making it challenging to identify which asset each one is associated with.
The purpose of this document is to explain how to add the CAT instance name to the faceplate title. More generally, the document explains how to access the faceplate title from C# code.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • IEC 61499
Rate this article:
