EcoStruxure Automation Expert: Create CAT HMI with Custom Properties
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert: Create CAT HMI with Custom Properties
  • Eric_Coudurier
    Eric_Coudurier
  • TristanPowell
    TristanPowell
  • Vartika
    Vartika
EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander Eric_Coudurier Lt. Commander
‎2021-12-13 07:28 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 04:02 AM
When creating a CAT using multiple animated symbols or SubCats and using an instance of that CAT in a canvas, the parameters of the built-in objects are not displayed and cannot be modified.
The aim of the document is to explain how to display the properties of embedded objects (animated symbols or SubCATs) in order to be able to modify them in the instance of the CAT.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
Tags (2)
  • cat
  • EAE
Rate this article:
(1)
100% helpful (1/1)
