EcoStruxure Automation Expert: Changing the Animation Color of Common Process Library Objects
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • EcoStruxure Automation Expert: Changing the Animation Color of Common Process Library Objects
  • Eric_Coudurier
    Eric_Coudurier
  • Vartika
    Vartika
EcoStruxure™ Automation Expert
SE.AppCommonProcess library for EcoStruxure™ Automation Expert
Back to Industrial Automation Knowledge Base
Lt. Commander Eric_Coudurier Lt. Commander
‎2022-09-29 06:19 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 04:02 AM
The animation colors of the objects in the SE.AppCommonProcess library should be able to adapt to the users' standard. The Grey and White colors used in the Situational awareness standard are sometimes not adapted to the needs.
There are several ways to adapt the animation colors of the library, from the simplest, using the standard functions of EcoStruxure Automation Expert, to the most flexible, allowing customized animation colors for each object instance.
This document presents different ways to change the animation color of the common process library objects in EcoStruxure Automation Expert.
3 methods are presented:
  • a simple method using the standard parameters to modify the color animation of all objects in the library.
  • A static method using the instance properties to customize the animation color of each instance.
  • A dynamic method to change the animation color of an object, directly from the logic.
Example of dynamic color change:
These methods can be applied to change the color of any graphical objects.
The Solution archive example is attached ( EcoStruxure Automation Expert V22.0)
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • Automation Expert
MotorColor_20220928-1825.sln.zip
Rate this article:
(1)
100% helpful (2/2)
