The BMENOR2200 can be easily configured to work in non-secure mode and many applications will use this. However, if a more secure connection is required, then this requires some additional configuration.
This document describes the extended configuration required for the module to run and communicate in secure mode.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
