Architecture using Modicon M580 with PTP protocol (PMEGPS0100) and the solution accuracy
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • Architecture using Modicon M580 with PTP protocol (PMEGPS0100) and the solution accuracy
  • MarceloPessoa
    MarceloPessoa
  • Vartika
    Vartika
Modicon M580
Back to Industrial Automation Knowledge Base
Lieutenant JG MarceloPessoa Lieutenant JG
‎2022-04-05 04:28 PM
Last Updated: Lieutenant Vartika ‎2023-11-23 01:35 AM
The EcoStruxure architecture and platform is open and interoperable, as noted in this document. The transparency of the Modcion M580 ePAC controller enables multiple architectures without the need for switches while maintaining network transparency. As it is open and transparent, it allows the use of a third-party module from Monaghan (approved) using the PTP protocol to guarantee an accuracy of 1ms for the SOE (Sequence Of Events) digital inputs.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • M580
Rate this article:
100% helpful (1/1)
