Adjust the Performance of Software Participants in EcoStruxure™ Process Expert
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • Adjust the Performance of Software Participants in EcoStruxure™ Process Expert
  • Michael_Chan
    Michael_Chan
  • Vartika
    Vartika
Back to Industrial Automation Knowledge Base
Commander Michael_Chan Commander
‎2021-07-27 10:58 PM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
  • EcoStruxure™ Process Expert is based on the collaboration of different software (called "participants") and a single database for the control system application, with the capability to accept new participants and third-party components
  • Each EcoStruxure™ Process Expert configuration embeds at least one virtual machine, which runs the software participants required to design and operate the control system
  • If user find extremely slow and sluggish performance whenever working with the software participants, user might need to adjust the virtual machine parameters
Each virtual machine is allocated the following default resources:
  • 4 GB of memory
  • 2 logical processors
If the virtual machine hosts memory-intensive software applications (like Control, Supervision and third-party applications), user might need to allocate more RAM or logical processors to ensure virtual machine doesn’t need to swap back and forth to disk.
System Server Configuration WizardSystem Server Configuration Wizard
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • PROCESS EXPERT
Rate this article:
(1)
100% helpful (1/1)
