AVEVA Plant SCADA: Date Picker with Calendar Genie
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • AVEVA Plant SCADA: Date Picker with Calendar Genie
  • kingslim
    kingslim
  • TristanPowell
    TristanPowell
  • Vartika
    Vartika
Citect SCADA
AVEVA
AVEVA™ Plant SCADA
Back to Industrial Automation Knowledge Base
Lt. Commander kingslim Lt. Commander
‎2023-06-06 12:46 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
Historically, picking a date in Citect has always been achieved using the Microsoft Date and Time Picker Control 6.0 Active X object that comes along with most Windows installation. However, as time progresses on, this Active X is no longer as popular as it used to be. Often, projects which uses the Active X, which are migrated from older systems into a new Windows 10 or above environment will fail on Compile. And installing the Active X is often difficult because it may require installing a whole bunch of un-related software just to get it. And many times, even with the Active X already in the environment, the project still does not Compile, or fail to run properly.
There is an alternative to using Date and Time Picker Control 6.0 Active X and this article is to introduce how to use the Calendar Genie in lib_controls Library to do that. It will involve the implementation of a Callback Function, and this article explains how this is to be created and used.
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
  • Transport
Rate this article:
100% helpful (1/1)
