AVEVA Plant SCADA (Citect) with Microsoft Forms 2.0 Active X
Industrial Automation Knowledge Base
Access vast amounts of technical know-how and pro tips from our community of Industrial Automation experts.
  • Industrial Automation Knowledge Base
  • AVEVA Plant SCADA (Citect) with Microsoft Forms 2.0 Active X
  • RobertSanders
    RobertSanders
  • TristanPowell
    TristanPowell
  • Vartika
    Vartika
Citect SCADA
AVEVA
AVEVA™ Plant SCADA
Back to Industrial Automation Knowledge Base
Lt. Commander RobertSanders Lt. Commander
‎2022-09-08 09:28 AM
Last Updated: Lieutenant Vartika ‎2023-11-21 02:07 AM
When restoring an AVEVA Plant SCADA (Citect) project which has used the Microsoft Forms 2.0 Active X as part of the graphics pages and popups - while upgrading, the graphics builder will generate errors for the missing Active X objects. This is due to the Microsoft Forms 2.0 no longer being installed as part of Office or Windows OS.
Microsoft Forms 2.0 has become difficult to find and install, which makes moving away from Microsoft Forms to a suitable alternative difficult as you no longer can test to the original functionality.
This solution should only be used for discovering the functionality of the Pages and popups that are using Microsoft Forms 2.0 and upgrading them to more suitable technology. It cannot be used on a live running system.
It is still possible to download a product called ActiveX Control Pad, which is a tool that makes it easier to add ActiveX controls to the HTML of a web page. You can no longer use the tool, however, as part of the setup it installs Microsoft Forms 2.0.
This Knowledge Base Article includes the Setup file called setuppad.exe or it can be downloaded from
http://download.microsoft.com/download/activexcontrolpad/Install/4.0.0.950/WIN98MeXP/EN-US/setuppad....
Once setuppad.exe has been downloaded right-click > Properties > Compatibility and tick ‘Run this program in compatibility Mode’.
Microsoft Forms 2.0 will now be installed and available to use within the Graphics builder
Disclaimer
The views and opinions expressed in this article are those of the author(s) and do not necessarily reflect the official policy or position of Schneider Electric.
setuppad.7z
Rate this article:
(2)
100% helpful (1/1)
